Distributor Vac Advance 1959 Lincoln 430
Discussion about ignition, timing, points, conversions and div. tune up recommendation.
Post by 59lincolnrag » Sun 8. Mar 2009, 09:26
Distributor Vac Advance 1959 Lincoln 430.
Can any one tell me if there is a supplier for a vacuum advance unit for a 430 MEL Engine.
Here is what I have. Part number for the distributor. #FEW 1212 7-H (922)
I also found this part number of the actual part on my parts car....#FEK 12378-E
THIS PART HAS A STRIGHT ARM AS OPPOSED TO
......ANOTHER PART THAT HAS A CURVED ARM??.....tHIS IS ALSO A 1959 LINCOLN
Re: Distributor Vac Advance 1959 Lincoln 430
Post by Theo » Sun 8. Mar 2009, 10:34
Maybe this could be an alternative Part Number: M1129331
Manufacturer Number: 29331
http://cpwstore.carpartswholesale.com/c ... 1959)&sv=0
You also might be lucky at http://www.lincolnlandinc.com/
Post by KULTULZ » Sun 8. Mar 2009, 11:10
The NIEHOFF PN is on the box. The FORD P & A PN is below the photo.
FORD PN B7AZ 12370-A
B7AZ 12370-A.jpg (21.98 KiB) Viewed 97129 times
Post by 59lincolnrag » Mon 9. Mar 2009, 05:23
Thank you Kultulz and Theo.
In the third picture, my other 59 430 has a curved arm ....would this be a replacement unit?
I have not looked at the part number yet...Maybe a distributor out of a 462 motor?
Post by KULTULZ » Tue 10. Mar 2009, 03:06
There was mixed production during that period. The straight arm is early design, the bent arm later design. That is why the DIST I.D. NO. is so important in ordering the correct service parts.
B9AF 12370-A_1.jpg (13.4 KiB) Viewed 97105 times
Reason: To Add Information
Post by 59lincolnrag » Fri 13. Mar 2009, 14:57
Thanks to all of you ....Very good information.
I found a new part and will post it in the DIY section.
Return to “MEL Engine Ignition and General Electrical Topics”
