trying to figure out which engine i have (430 4v)
stephen p
- Music instruments you're playing: i play the radio.
hey, i bought a 1962 continental, and i noticed the engine was a factory 4v, with a carter/afb carb. anyhow, it seems like most of the 62 lincolns i've seen were 2 bbl. also, the breather and valve covers are chrome, and all the others i've seen were painted, and if i'm not mistaken the intake was stamped "c3xxxxx" (i need to go get the whole number) which would indicate to me it's a 63 model engine. anyhow. i'm sure it's just a mundayne engine, but i want to make sure it's not anything special before i go selling the car
Re: trying to figure out which engine i have (430 4v)
Post the rest of the numbers after C3, and if you can get the numbers off the block. It might just be the top end that was changed.
stephen p
where on the block would they be located? (sorry, i know zero about these)
Hello Stephen,
Try this link it may help. The photo will be the fourth post down.
viewtopic.php?f=2&t=561
stephen p
i finally got the number off of the intake. c3ve 9425-d
