DIY 010 Super Marauder Restoration, Installation and Tuning
Post by 59lincolnrag » Wed 11. Mar 2009, 15:46
Super Marauder Restoration, Instalation and Tuning.
Preview...
Staff Sergeant
Staff Sergeant
Re: Super Marauder Restoration, Instalation and tuning. DIY
Post by reijerlincoln » Thu 12. Mar 2009, 07:52
That's a cool looking air filter housing. Rare as hen's teeth, I take it?
Post by KULTULZ » Sat 21. Mar 2009, 03:15
This is the correct appearance-
1958 MERCURY SUPER MARAUDER INSTALLATION
1958 MERC Montclair SUPER MARAUDER.jpg (18.13 KiB) Viewed 21017 times
Post by Theo » Sat 21. Mar 2009, 03:20
Yeah, an all time tasteful package. Thanks for the photo.
Post by 59lincolnrag » Wed 12. Aug 2009, 15:10
OK ......first things first
Dont pay a lot for your filters .....$89.00....NO!
Baldwin filter site...
http://www.baldwinfilter.com/
Here are some part numbers...
ACDELCO A87C
AIR REFINER ARP22
AMERICAN PARTS 1137
BALDWIN FILTERS PA632
CHAMPION LABORATORIES AF48A
FORD MOTOR CO. FDJ-9601-A
FORD MOTOR CO. EDH-9601-A
FORD MOTOR CO. EDJ-9601-A
FORD MOTOR CO. EDK-9601-A
FORD MOTOR CO. EDU-9601-A
GENERAL MOTORS CORP. 1554082
MOTORCRAFT FA48
PUROLATOR AFP22
PUROLATOR 6934425
STAY READY SRP-A22
WESTERN TOOL CO. WA22
Dimensions...
O.D. 9 23/32" (246.9) to 20 23/32" (526.3)
I.D. 7 5/16" (185.7) to 18 5/16" (465.1)
Length/Height 1 3/4 (44.5)
Post by 59lincolnrag » Wed 12. Aug 2009, 15:24
I guess your wondering where in the.. H-E-Double hockey stick ..LL..... do you get a Super Marauder Wing Nut!!!!!
I found a set on E-bay For $145.00!!!!!!!!
Are you kidding me!!!!!
Well if you as old as me I’m sure you remember Lots of guys had them on their cars ......
Mr. Gasket 6398 Wing Style Air Cleaner Nut
Amazon dot com in stock!!
ONLY $3.88!!!!!
Exact Match
But Wait ...theres More!!!
Mr. Gasket 9829 Chrome Valve Cover Wing Bolt set
and a matching breather cap
Mr. Gasket 2060 Chrome Push-On Breather :D
Post by Theo » Wed 12. Aug 2009, 15:42
Good work Anthony.
Also consider the "Part #" section for posts regarding shopping recommendations and part numbers.
Thanks for letting us know.
Post by 59lincolnrag » Wed 12. Aug 2009, 15:51
Super Marauder spacers ......
I needed to machine new insulating spacers for a 3 x 2 setup. The old material looks like a brown Bakelite ..It was deteriorated.
McMaster Carr has various grades of phenolic or garolite. I selected G-10 Fiberglass reinforced Industrial laminate ....it is a phenolic material
I also mached 3 aluminum plates …..Thanks Bobby B. (My tool maker)
A stacked arrangement will be installed under each carburetor. .....
gasket, aluminum plate, gasket, insulator and gasket....
That should keep the heat down.....The Garolite can withstand 325 F ........
Notice the locating pins .....No magic here. Drill press and band saw. Also three new Stainless studs for the air cleaner.
The Mr Gasket wing nuts look right at home......just a quick mock up...
Post by Theo » Wed 12. Aug 2009, 15:59
Anthony, why are you sandwiching those aluminum plates? Is that the way they used to roll off the line? I sure do miss s.th.
Post by 59lincolnrag » Wed 12. Aug 2009, 16:18
The picture you see is not what will be under the carb .....
We simply stacked all the materials to cut out everything at once….
From the factory it was a paper gasket the Bakelite insulator another gasket then the carburetor....
So ….for better Insulating qualities.
Paper gasket
Aluminum plate
another gasket
Bakelite insulator
and then another paper gasket
and finally the Carburetor.
So I’m really only adding a thin Aluminum plate to each one. Since our Gasoline seems to evaporate very quickly this seems like a reasonable “fix”.
