LOOK WHAT I FOUND
LOOK WHAT I FOUND
Post by Chris Craft crazy » Mon 30. Nov 2009, 18:52
I drove to Detroit and back today... 13.5 hours round trip, and I bought this....
and yep, thats exciting, but look at this...
and look at where it came from..
and look what's in it. this is the mechanics maintenance manual..!
I just about crapped when I saw it sitting there.. :mrgreen: Each section of the car has a complete maintenance, schematic and tool listing. Maybe these are common, but I didn't think so. All the torque specs, everything
Low58Corsair
Re: LOOK WHAT I FOUND
Post by Low58Corsair » Mon 30. Nov 2009, 19:41
that's a sweet score, you'll have to post pics as you build it up. what are you going to install it on?
Post by Chris Craft crazy » Tue 1. Dec 2009, 08:09
It's for my Chris Craft supersport... see my other threads.
Staff Sergeant
Staff Sergeant
Post by reijerlincoln » Sat 5. Dec 2009, 15:03
Nice intake! Does it need custom heads?
Post by Chris Craft crazy » Sat 5. Dec 2009, 20:23
That is an original Ford motor company super marauder intake.... so just a bolt on.
Now I need carbs...
Ted
Post by Ted » Sun 6. Dec 2009, 07:29
The Mopar six pack carbs are a bolt on. I have the 440 carbs on mine and simply bored the throttle holes in the intake to match the carb bore sizes on the end carbs. The center pivot carb bowls on the Mopar carbs just clear the distributor without having to change over to the side pivot flat faced bowls.
Post by Chris Craft crazy » Mon 7. Dec 2009, 17:08
I am going to chicken out, and send the manifold to Joe Bunetic, who I have spoken to a couple of times on the phone. I need mechanical linkage, and marine returns on the tubes..
By the way Ted, been reading all your online articles. Fabulous reading, very interesting and informative. Thanks.
buddy67lincoln
Post by buddy67lincoln » Tue 8. Dec 2009, 10:49
John Bunetic came highly recommended for tri power carbs. I came across him on a website for tri power history. You have to call him though...no emails! I hope to call him soon myself for my set up. I need linkage and since mine were 3 seperate 2 barrel carbs turned into tri power carbs...i want it scoped out to make sure it will all work out. I am not a carb man myself but this guy knows his stuff!
John Lyman
Post by Theo » Fri 11. Dec 2009, 08:03
Ted, you got a message. Please check your PM box.
Thanx
buddy67lincoln
Post by buddy67lincoln » Fri 11. Dec 2009, 08:08
I have a 58 service manual but there is nothing about the tri power in it. Does your book have it in there? I bought the book to understand the cooling system but was hoping it was in there! I do have some copies of info though. Thanks
John Lyman
