1958 Continental Claret -
Discussion about Lincoln
Re: 1958 Continental Claret -
Post by Shelby#18 » Mon 21. Oct 2019, 13:38
Your progress is impressive!
novetti
Post by novetti » Mon 27. Jan 2020, 03:27
Fine Gentleman and Ladies
Just uploaded this video a made a couple months ago when I had my brother visiting and helping out
Cheers
Julio
Post by Shelby#18 » Thu 6. Feb 2020, 17:19
That sure sounds nice!
Partsetal
Post by Partsetal » Fri 7. Feb 2020, 11:53
Where did you get the vanes for the vacuum pump?
novetti
Post by novetti » Thu 13. Feb 2020, 01:51
The Vanes in the pump were ok and reusable so I didn't need to source them. They are Fiber Phenolic material.
However if I needed, I would probably source a a Phenolic fiber board and cut my own vanes. Wouldn't be too difficult.
A quick search I found this.
My engine is back in place so I can't measure but I believe they were 1/4'' thick.
Garolite Micarta 1/4 thick
https://www.ebay.com/itm/Garolite-Micar ... 4d1715e87b
novetti
Post by novetti » Thu 4. Jun 2020, 00:46
Lets put some movement in this Forum Gentleman
Some more photos from tasks I did in the last months.
Flexplate tooth with teeth very worn - most like from trying exceesively to crank the seized engine.
Fabricating from scratch rear wheel well panel sections.
Pressure regulator had a blown part from one of the valves. I sourced a replacement body for that.
What have you guys been doing?
Cheers
novetti
Post by novetti » Sun 28. Jun 2020, 20:56
More Panelwork / Fabrication Updates
Outer bottom rear rocker sections here - Both sides
novetti
Post by novetti » Sun 28. Jun 2020, 20:57
Rear Rockers inner section
novetti
Post by novetti » Sun 28. Jun 2020, 20:58
Right Side skirt flange fab
novetti
Post by novetti » Sun 28. Jun 2020, 20:59
Mid section Rocker fixes
