1958 Continental Claret -
Discussion about Lincoln
Re: 1958 Continental Claret -
Post by Shelby#18 » Thu 13. Aug 2020, 08:33
That looks good to me! The job you are doing is fantastic.
novetti
Post by novetti » Fri 18. Sep 2020, 00:29
Work is happening here dudes
Doing 1 hr minimum after work at night during the working week, full Saturdays and Sundays.
Primed once all outside panels. Door sills already painted and doors re-installed in the car.
Adjusted door gaps.
Did the first block sanding on the primer in the rear quarters and left fender. Will need to reprime for final blocking....
novetti
Post by novetti » Fri 18. Sep 2020, 00:32
Does anyone have have a clue where I could find the middle finishing strip between the two fibreglass parade boots?
It was missing from the vehicle when I got it.
Cheers
Julio
novetti
Post by novetti » Wed 21. Oct 2020, 05:09
Lets keep shaking this thread up
3rd Reprime and block sanding prior Basecoat + Clear
novetti
Post by novetti » Wed 21. Oct 2020, 05:11
Package Tray and Trunk in Color...looks good under the sun.
Had the normal nibs, and a could or runs, will be rectified with denibbing + cut and polish.
More to come... stay tuned
novetti
Post by novetti » Wed 21. Oct 2020, 05:13
I am taking easy to not upset my yearly guests...4th year in the run the nest is reused by a Wagtail couple.
This time 3 chicks. One felt from the nest today and I manage to put it back there without issues.
I will wait until they depart to spray both long sides.
Cheers dudes
Post by Chris430 » Wed 21. Oct 2020, 05:22
Cheers dudes
I have a vent a hood exhaust on the side of the house. Birds move in and I plan on plumbing it in when they leave. This is year three.
I likely don't have it but what does the piece you need look like?
novetti
Post by novetti » Wed 21. Oct 2020, 17:06
I don't even have a photo from this trim piece to see what looks like (and potentially make a repro piece myself).
Photos and more info would be greatly appreciated. I think made in thin gauge Stainless Steel I should be able to cut and fold something acceptable.
Not sure how it is secured in place.
Cheers
Julio
novetti
Post by novetti » Wed 28. Oct 2020, 18:19
Hood sprayed
The usual nibs and the mosquitos...
Post by Chris430 » Wed 4. Nov 2020, 20:42
I have a few odds and ends but nothing that size. That is some talented paint mixing to duplicate quart by quart.
