1958 Continental Claret -
Re: 1958 Continental Claret -
Nice metal fabrication. Do you have your own English Wheel?
novetti
- Music instruments you're playing: Bass, Classical Guitar
Hi Chris
I have only a few metal fab tools
-Shrink/Stretcher Dies
-Small and Cheaper Beadroller from Eastwood
-Cheap and nasty chinese pan brake
No English wheel yet. I might invest in one or make it from scratch if I find the need for one. I am by no means a master in this craft yet, but just shows a lot can be achieved if you are patient and willing to give it a go.
I do have another project (a Citroen HY van) with lots of rust that will require more than the tools I listed above, but I need to finish this Continental first before starting the other. For that one I will need to replace extensive sections of metal, I am thinking even to roll some of the corrugated panels from scratch...
Cheers
Julio
Cheers
Julio
novetti
Undercarriage final Treatment of rear section post all metal fab and welds completed.
- Phosphoric Acid
- Primer
- Seam Seal
- Undercoating
- Paint
- Phosphoric Acid
- Primer
- Seam Seal
- Undercoating
- Paint
novetti
Body Prep - Sanding old coating with #80 / #120 / #180
A lick of body filler in some areas, and Primer applied with a roll. Block sanding and re-prime coming next.
novetti
Removing the base of the front seat, found some items hidden in the lower body cavities.
Old Eveready flashlight (made in USA), a small jar with gold paint pigment, a leaflet for a protable cooler and a very cool coloured Inflatable ball.
I guess those items must been there since the 60's....
Like the postage find. I bet it was nice to have the dollar go further back then. I found a shop bill in an old Ford pickup. It was about $100 for parts and 12 hours labor. Were the Lincoln build sheets under the seat back then?
novetti
Hi Chris,
Haven't seen the bill sheet yet (if its still there). tonight I will take the seat base out and look for it properly.
Chipping some time on the car everyday (even if just 30 min after work during the week). I want it painted before end of September.
One repair is taking longer to fix is the buckling in the front Left fender due the previous collision. I need to push it in approx 10mm over a large area. Looks like it requires shrinkage etc. The Fender was previously replaced in the past and was poorly welded at the rear where it meets the door.
I Found the sheetmetal at this car is a bit more difficult to repair due the ample straight areas.
novetti
Before when I got the car
Now After I fixed most of the dents and distortion
