Secondary Block Theromostats: 1963 Lincoln 430
kultdouble
Editorial Group
Editorial Group
Post by kultdouble » Mon 27. Sep 2010, 13:09
Originally postet by "Roland "
The 430 in my '63 Lincoln had a 3 level thermostat system which included a small thermostat in each cylinder bank which opened only after the engine was partially warmed.
When I rebuilt the engine I left these out as I was unaware of any replacement source and didn't want to take a chance on overheating.
Is there a source for these and has anyone encountered a similar situation?
Re: Secondary Block Theromostats: 1963 Lincoln 430
Post by KULTULZ » Mon 27. Sep 2010, 13:13
MEL Lower Block Thermostat
In-Block Combustion Chamber uses aluminized oversize valves with zero- lash hydraulic lifters; gives longer valve life, better intake and exhaust action, and smooth even combustion.
3-Stage Cooling circulates coolant in three stages: (1) to intake manifold and cylinder heads; (2) to block; and (3) to radiator. Provides fast starting warm-up and progressive temperature control utilizing three thermostats.
Fuel System Advances feature exclusive preheated carburetor air system and water-jacketed intake manifold to keep the fuel-air mixture at proper temperature for maximum combustion efficiency.
This is a set that I found on e-bay a while back. I have not come across a vendor that services them. The members at the LCOC Board leave them out regularly and I have heard no adverse comments. The diverter(s) is more important as it directs coolant to the heads and intake and that coolant heat is needed for the carb pad warm up as there is no heat riser provision engineered into the MEL engine.
Post by KULTULZ » Mon 27. Sep 2010, 13:15
Block Thermostats Update
65/72 LINC-MERC MPC
The use of the block thermostats was discontinued in the 1963 model year. The notation is under PN C3VY 6009-B (cylinder assembly).
They are no longer available for service and the particpants at the LCOC Board have not noticed any changes in performance or operation without them. The diverters are still necessary though.
The block thermostat is assembled in reverse from a normal thermostat in that the temp sensing bulb is on the opposite side of the opening/closing spring.
60/78MarkVConverts
Post by 60/78MarkVConverts » Sat 1. Feb 2014, 03:20
Most of the design requirements were driven by putting advanced in the Lincoln/Continental automobiles. The 2 in block thermostats, with a cold engine hold the coolant in the heads, they warm up faster, and this coolant then reaches heater core much faster for interior comfort. Secondly, rapid coolant warmup brings the carburetor up to efficient operating more quickly, for better gas mileage. Gas mileage became so important that from 1960 to 1962 the only engine available had a 2-barrel carburetor. This can only be described as a near-disaster. The first thing I have done after purchasing any 60 Continental is put a 1958, 59 or 65 4-barrel carb on it!!
in about 1967, Ford issued a service bulletin that it was ok for the block thermostats to be left out of the engines. On the several MEL engines that I have removed water pumps on, all but 2 or 3 of them were still ok. And in 1975 I queried the Richmond, CA distribution center and bought the last 5 that they had. (Plan Ahead!) When I find them, I carefully work them out and test them in a pan of boiling water. They will either open (good), or they won't (bad).
The MEL engines MUST have good diverters in them or there will much reduced coolant flow to the heads!
