I'm new, need some advice.....
Posted: Mon 19. Jul 2010, 18:41
Hi my name is Mark. I'm trying to figure out this forum...hope this is the right place for this. Anyway I am working on a 1962 430 out of a Lincoln Continental. I wish I found this forum sooner. Any help in finding parts and suppliers would be greatly appreciated. I drove the car, did a leakdown...bad results some holes 40%. Pulled engine taken apart. Crank is cracked found one @ Lincolnland, I need .030 over pistons and am not sure where to get them from, as some posts I've seen here talk about wrong dome(for lack of a better term) sizes for their application. Camshaft is worn out as well. I have found some usefull information here just trolling around but now I have joined and am hoping to get more. I liked the heavy duty oilpump drive shaft I saw on one post. I want a new oilpump but not a high pressure or high volume, any ideas? The nuts on the rod bolts are an odd size, I used a metric six point to get them off. I am concerned about not getting the correct pistons and don't want to loose too much compression w/modern/thick head gaskets.
Thanks so much, glad to be here,
Mark
Mark
