430 mel
Linc65
- Music instruments you're playing: None
430 mel
Hi my name is Lonny. I own a 65 continental with a 430. What I am wondering is if the engine can be lifted by the heads where the intake manifold bolts. I'm trying to replace the motor mounts and at the same time removing the oil pan for a new gasket and oil pump. Not many places to jack up motor from beneath. I will also be replacing exhaust manifold gasket in drivers side. Any info thanks
Re: 430 mel
There are lifter plates available that bolt on on your carb flange. They seem to work pretty well. I would probably hesitate to bolt on the header bolts alone. Maybe a combination of various points will do the trick. lifting the engine without the trans might help make things lighter on the bolts.
Linc65
Re: 430 mel
Yeah thank you. Have you lifted these engines with the carb plate bolted to the intake? Just was not sure the weight of the engine would be to much. Not that the bolts are not enough just didn't want to risk cracking the cast intake seeing how hard they can be to find. Also thanks for the site very good info here. Hope to have the car back to reliable standards in a couple weeks.
Re: 430 mel
Yes, I've done it w. an FE engine. Works fine. I've also used home made brackets that boltet on the cylinder heads front and back sides. Not sure w. the MEL engine. My last built was 20 years ago and can't really remember if it has those bolt holes at the same location as the FE engines.
