valve covers
Exchange knowledge and discuss MEL engine related aftermarket engine parts like cams, rods, chains, intakes and lots more.
buddy67lincoln
Re: valve covers
Post by buddy67lincoln » Thu 16. Dec 2010, 10:28
I should be able to use the timing cover without fuel pump if I use an electric fuel pump too, correct? Shouldn't be any different I would think.
Re: valve covers
Post by Theo » Thu 16. Dec 2010, 16:04
Correct. Just make sure to use a fuel pressure regulator amd a fuel pressure gauge. Adjust the pressure regulator according to the carb's recommended psi.
Some fuel pumps come with an anti roll function.
Return to “MEL Engine Aftermarket Parts”
