Mercury Edsel Lincoln 410 430 462 EFI fuel injection
Exchange knowledge and discuss MEL engine related aftermarket engine parts like cams, rods, chains, intakes and lots more.
Post by 59lincolnrag » Wed 29. Jun 2016, 16:51
Mercury Edsel Lincoln 410 430 462 EFI fuel injection Barnett High Performance
It features
Fast Easy fuel injection kit complete.
EGR: No
Injection Style: Throttle body
Metering Style: Speed density
Intake Manifold Included: Yes
Intake gasket included: Yes
Engine Block Style: Stock/OEM standard deck
Fuel Rails Included: Yes
Throttle Body Included: Yes
Throttle Body spacer included: Yes
Throttle Body Mounting Flange: 4-barrel square bore
Venturi Quantity: 4
Throttle Body Material: Cast aluminum
Throttle Body Finish: Natural
Injectors Included: Yes
Calibration Module Included: Yes
ECM Included: Yes
Wiring Harness Included: Yes
Oxygen Sensor Included: Yes
Fuel Pump Included: Yes
Fuel Pressure Regulator Included: Yes
Distributor Included: Yes MSD/Barnett (your core required)
MAP Sensor Included: Yes
IAT Sensor Included: Yes
TPS Sensor Included: Yes
IAC Motor Included: Yes
Timing cover included: Yes
Quantity: Sold as a kit.
Notes: Designed for engines making less than 550 hp. Not recommended for supercharged applications.
link below:
http://www.ebay.com/itm/262500770864?it ... em&vxp=mtr
congo
Music instruments you're playing: piano
Re: Mercury Edsel Lincoln 410 430 462 EFI fuel injection
Post by congo » Sat 13. Aug 2016, 19:46
That's cool! The fuel pump removed from the top of the timing cover is a nice touch and would clean the front of the engine up nicely. I wonder if they only include the intake manifold for 2 barrel cars. Those FAST systems should just bolt right to the carb flange on the 4 barrel cars.
Return to “MEL Engine Aftermarket Parts”
