AFTERMARKET PARTS BACK!!!
bestrada11
HELLO ALL ITS BEEN A WHILE I USED TO BE HERE DAILY MULTIPLE TIMES A DAY. I STARTED MAKING AFTERMARKET PARTS BY SUBBING OUT THE WORK TO FRIENDS AND BEING THE GO BETWEEN GUY. I USED TO OWN A POWDERCOATING SHOP SO I WOULD TRADE OUT THE WORK AND BASICALLY DO THE DESIGN AND RELY ON OTHER PEOPLES MACHINES. I GOT SICK IN 09 AND DISAPPEARED AND HAVE SINCE SOLD MY BUSINESS AND SET UP MY OWN MACHINE SHOP ON THE SIDE BUT I RUN A MACHINE SHOP AT A PLASTIC INJECTION PLANT. I PURCHASED A CNC MILLING CENTER AND A TWIN TURRET TURNING CENTER THAT I CAN BASICALLY MAKE ANYTHING BILLET YOU COULD EVER NEED I ALSO HAVE ACCESS TO 4 AXIS WIRE EDM CAPABILITIES SO FOR GEARS AND SUCH THIS IS NOT A PROBLEM AT ALL. IM SELLING A BLOWER INTAKE A ROLLER CAMS I HAD COLLECTED IF ANYONE IS INTERESTED.
Lincolnlvr
Re: AFTERMARKET PARTS BACK!!!
Do you know of anyone that can make some connecting rods for a 462? Trying to locate some after market rods but none seem to be available. They're 6.600 center to center and have BE 2.750 and SE .975 . Nothing even close anywhere.
Lincolnlvr
What type of roller cams you have ? Any hydraulic ? Have a solid Isky cam but too extreme for street.
