Confirm ID on Autolite 4100?
Posted: Fri 14. Oct 2011, 22:30
Hello all,
I have an early Autolite 4100 carburetor that I believe is for a 1959 383 Mercury; it has the long accelerator pump snout,
the choke plate with the spring-loaded flap, steel balls pressed in to seal the internal fuel transfer passages, and an
"EDG" stamp on the side of the float bowl. It is in fairly good condition; needs new slosh tubes to be complete. I rebuilt
it a couple of years ago and it ran OK on the Q-code 428 in my truck, but didn't have a kickdown lever for the automatic transmission so I replaced it with a more appropriate C5AF-F. Now I just want to get it out of my garage, hopefully to
a good home with someone who needs it.
Can anyone confirm what this is?
Thanks in advance - Tracy
