MEL 410 Engine Specifications
Posted: Wed 24. Dec 2008, 12:41
Please help adding, correcting, discussing and completing data to this section. This specification run down is provided by participants of this MEL Engine Forum and me. To have it clearly arranged I constantly keep merging the info into this single post. The contributor's original post will remain below.
Short Block
8 Cylinder
90° "V"
O.H.V.C.
410 cid
V8
Compression Ratio...........................10,5 : 1
Horsepower Taxable SAE:.............................345 hp
Firing Order......................................1 5 4 2 6 3 7 8
Bore and Stroke.................................4.20" X x 3.70"
Con Rod Length..................................6.599" - 6.601"
Piston Pin Dia................................... 0.9750" - 0.9753"
Main Bearing Bore Diameter:
Code Red:............................................3.0922" - 3.0926"
Code Blue............................................3.0926" - 3.0930"
Crankshaft to Main Bearing Clearance.
Fresh...................................................0.0009 - 0.0029
Wear Limit...........................................0.0036
Cam Bearing Bore - Diameter:
................................................#1............0.875" - 0.876"
................................................#2............0.875" - 0.876"
................................................#3............0.875" - 0.876"
................................................#4............0.875" - 0.876"
................................................#5............0.875" - 0.876"
Tappet Bore Diameter:..........................0.875" - 0.876"
Distributor:
Rotation..................................................counterclock wise
Shaft Bearing Bore Diameter:.................0,452" - 0,4535"
Mounting Pad to Distributor Gear Thrust Boss................3,0585" - 3,0615"
Mounting Bore Diameter.......................1,602" - 1,603"
Engine Oil:
Capacity - Quarts (Add one quart when changing filter)..................5
Oil Pressure @ 2000 R.P.M (Hot).......................................................45 - 50 PSI
Viscosity @ above + 32° F...............................................................SAE 20 - 20 W
Viscosity .@ + 32° - -10° F.............................................................SAE 10 - 10 W
Viscosity @ below - 10° F................................................................SAE 5 W
OIl Change: .......................1st ........................................................@ 1000 Miles
..........................................2nd .......................................................@ 4000 Miles
........................................................................................................and each 4000 thereafter
410 cid block casting numbers:
coming soon
Cylinder Heads
Gasket Surface Flatness:.............................................0,002" in any 6" lenght or 0,004 overall.
Valve Guide Bore:....................Intake - Diameter Standard............................0,3728" -0,3735"
............................................Exhaust - Diameter Standard............................0,3728" -0,3735"
Valve Stem Diameter Intake .........................................................................................0.3715"
Valve Stem Diameter Exh..............................................................................................0.3697"
410 cylinder head casting numbers:
.......coming soon
Re: MEL 410 Engine Specifications
Posted: Wed 22. Apr 2009, 19:34
by KULTULZ
Engine Colors-
1958 EDSEL E-475 Artists Illustration_1.jpg (24.79 KiB) Viewed 56000 times
Green: (similar to 1978 Porsche "Fern Green" - DuPont code 273, Porsche code 45639AH):
Block, heads, water pump, intake manifold, oil filler tube, oil pan
Off-White: (Mix four parts Derusto Gloss White #874/D-23 and one part Derusto Gloss Almond #884/D-34):
Air filter cover, valve covers
Reddish-Orange: E-475 Stenciled on embossed letters
Gloss Black: Brackets, generator, fan, pulley, starter motor, flywheel cover, inner fender aprons, radiator
Semi-gloss Black: Frame, front suspension, core support, etc.
Natural: Transmission bell housing, distributor, exhaust manifolds, fender attaching bolts
FROM -1958 EDSEL INFORMATION PAGE-
