430 Super Marauder Carb needed
Advertise or Sell MEL Related Engine Parts Privately.
Wowcars
Music instruments you're playing: Radio
Post by Wowcars » Wed 24. Mar 2010, 06:52
I need to find the center carb for a 1958 Super Marauder tri-power asap. The Holley ID number on the air horn is: R-1673A Thanks!
buddy67lincoln
Re: 430 Super Marauder Carb needed
Post by buddy67lincoln » Sat 27. Mar 2010, 22:07
Good luck! There is however all 3 on ebay for $5,000. You can always make one from a regular 2bbl
John Lyman
vanscooter
Post by vanscooter » Sun 28. Mar 2010, 04:34
Actually that guy finally lowered his price to $ 2,000.00 but it is incomplete as well
buddy67lincoln
Post by buddy67lincoln » Sun 28. Mar 2010, 07:46
$2,000 wouldn't be bad if he had he linkages, bowls, etc. It is missing a lot. I have never seen the carbs separated but maybe you could somehow get ahold of someone who has the carbs but changed them for something else. But if it were me, I'd still keep them to have the whole setup be number correct even if I did not use them. If I ever stumble across some I will let you know. Good luck
John Lyman
Wowcars
Post by Wowcars » Sun 28. Mar 2010, 11:46
Thanks guys. I talked to tech support at Holley and they are sending me a marine fuel bowl with a internally adjustable needle (that is not supposed to be available without buying the whole carb) which should clear the air horn of the front carb. Since this isn't a absolute restoration, it should work. We'll see. I'll let you know.
Post by 59lincolnrag » Thu 22. Apr 2010, 05:30
I'm familiar with the set you have (e-bay special).... go to the DIY section. There may be some information you can use.
Check for fit between the throttle plate and the main housing....
If you don't set these carbs up correctly it will never run right.....
What is the application? ....what vehicle will you use it on .?
Return to “Ask for MEL Engine Parts”
