Cylinder Head Valve Diameters urgently needed
Posted: Thu 4. Feb 2010, 14:47
Hi everybody. can't believe that we have no valve diameters listed.Can s.o. chime in with the figures. I'd also like to feed my Desk Top Dyno with the data.
Thanks for tips or pointers.
Re: Cylinder Head Valve Diameters urgently needed
Posted: Mon 8. Feb 2010, 15:51
by Treinarts
2.19 and 1.88 on my 58 430 tri power. TJR
Posted: Wed 10. Feb 2010, 04:49
Do you have aftermarket valves installed? From two independent resources I've found out that the MEL valve sizes for Year 1958 are
Intake ...............2,140-2,150" and
Exhaust............ 1.770"-1.780".
Later than 1958 years' valve sizes have been reported to be smaller on the Intake valve while retaining the exh. valve size
Intake ...............2.09?
Posted: Wed 10. Feb 2010, 16:55
by Ted
Valve diameters as listed in my 1959 M-E-L Registered Mechanics Service Specifications Handbook are as follows:
Intake - 2.080-2.090"
Exhaust - 1.770-1.780"
Posted: Wed 10. Feb 2010, 18:11
Fantastic, couldn't be any better and good to know you have books. My AERA Cylinder Head and Block" manual is packed but it doesn't list valve diameter numbers. I assume you have that book too. If you don't have it let me know what figures you might need in the future and I'll shoot them into your direction.
Except for my incorrect listing of the post 1959 Intake valve diameter size your latest info on valve diameters corresponds fine with what I've previously listed. Basically valve diameter have only been downsized on the intake side from 1959 on.
Gawd! That year I was a 1 year old su##er with small stck valves that were leaking and suffering from blow by like crazy
So it all melts down to:
Year 1958 MEL Valve Intake ...............2,140-2,150"
Year 1958 MEL Valve Exhaust............ 1.770"-1.780".
Year 1959 MEL Valve Intake................2.080-2.090"
Year 1959 MEL Valve Exhaust.............1.770-1.780"
Posted: Thu 11. Feb 2010, 09:58
by Treinarts
As far as I know, those valve sizes are original. (2.19 and 1.88) I did not install them and they had old leaded gas seats on the exhaust side. I did replace those seats but did not change the valve size.
I have a set of 59 2 barrel heads at Slover's getting 2.25 and 1.88 valves put in them. Those original valves were smaller than the ones on the tripower engine. TJR
Posted: Mon 1. Mar 2010, 13:30
by Chris Craft crazy
Here are some additional valve related figures for the archives, taken from a 1958 Lincoln maintenance manual.
Valve guide bore:
Intake and exhaust standard 0.3728 to 0.3735
Valve seat
Intake diameter
cylinder head #5750064 0.2120
cylinder head #5750062 0.2060
Intake width: 0.060 to 0.080
Exhaust width 0.070 to 0.090
Intake angle 30 degrees
Exhaust angle 45 degrees
Valve stem to guide clearance
Exhaust 0.0028 to 0.0042
Intake 0.0010 to 0.0024
Posted: Tue 2. Mar 2010, 02:06
Thanks bunches. Additional info added.
