Valley pan info needed
Posted: Sat 26. Sep 2009, 14:56
by 56vicky430
Fill me in on the differences between valley pans. What type of modification has to be made to an older block to use PCV?
Re: Valley pan info needed
Posted: Mon 30. Nov 2009, 10:51
by Low58Corsair
I'm not sure, there's another topic that's working on creating a new valley pan for just this need, however I'm not sure if it's going to get off the ground. but this winter I'll be finding the answer to your question, possibly modifying mine to fit this need. I'll keep you posted as I go.
Posted: Thu 29. Apr 2010, 20:34
by 64Bezer
It's probably not factory on the cars, but my boat has a vac-u-pan setup that you can get from jegs. It does the same thing as a pcv.
-Rob
Posted: Sat 21. Aug 2010, 15:34
by KULTULZ
Basically, the rear road draft vent at the rear of the lifter valley (58-60) has to be removed and replaced with an expansion plug. You then use a 1961/ valley pan.
Previous Discussion-
viewtopic.php?f=2&t=230
