What valve springs are you using?
spectramal
Post by spectramal » Fri 26. Apr 2019, 11:47
I need to replace my original springs with something a little higher performance. Just wondering if you guys found a good spring to use. Most that I find in my comp book need to have the guide/spring seat milled down to fit. Is this a problem?
