1960 Mel Rebuild Question
Posted: Wed 5. Feb 2014, 17:17
by halloran
Hello everyone, my name is Nick and I am a new member of the website! I am currently restoring a 1960 Lincoln Premiere that has this very strange, very unique 430 engine and I have a slight issue with it that maybe someone can shed some light on. Currently, I started to press on the harmonic balancer/pulley assembly and noticed that it presses too far onto the crank by about a 1/4". I have changed NOTHING on the engine. Same pulley, same vane style power steering pump (new pressed seals of course). I know that the balancer is going on too far because the rest of the belts line up perfectly on the water pump and generator.
So I guess my main question is whether or not I can just get a little longer crank bolt to bottom out on the inside snout of the crank at the EXACT distance I need the harmonic balancer to travel as I press it in. So basically as the bolt bottoms out on the inside of the crank, the balancer would stop at the same time at the exact distance I need it to keep it in line with the rest of the pulleys. Is this a good idea? Does anyone know the exact crank bolt dimensions I could compare mine against to make sure I even have the correct OEM factory bolt?
Thanks for any input!
Re: 1960 Mel Rebuild Question
Posted: Sat 8. Feb 2014, 15:37
by congo
Hi Nick,
My MPC says that bolt should be 5/8"-18 x 1 7/8" long. There's also a washer but I'm not sure how thick it is (1/16, maybe?). I'd be afraid of the balancer shifting if it isn't snugged up against the PS pump, though.
Did you send your PS pump out to get rebuilt? If you did, is it possible they sent you one back from a different year? I think they changed in 61. Somebody else on this board might know more.
Posted: Sun 9. Feb 2014, 00:48
by halloran
Is the 1 7/8" bolt length the total length including the thickness of the head or is that from under the head and just the length of the thread? I never had the PS rebuilt but I did replace the front and rear seals as well as the main rubber gasket. At first I didn't have the front seal all the way in which was causing the balancer to slightly rub against that metal seal but I got a new seal and was doubly sure to press it all the way in that way that floating shaft would not leave any gaps on either end. You can see from the picture below what happens if you don't press the seal all the way in to the front of the PS pump. Keep in mind this is from just two hand rotations of the crankshaft...
Posted: Thu 13. Feb 2014, 20:17
by keithol
The harmonic balancer must be pulled all the way in against the pump drive or everything will work loose and wear out . Its been several years since I worked on mine , so I don't remember for sure but I think there may be a spacer between. Possibly it was left out at a previous timing chain replacement or something like that. I have seen engines run with pulleys out of line several times without anyone noticing. Or is there a possibility the ring rolled away and you didn't see it ?
Posted: Sat 15. Feb 2014, 22:51
by halloran
Posted: Fri 21. Feb 2014, 09:32
by halloran
Holy moly still no information out there on what the deal is between these two pulleys? Was one maybe off a Mercury and the other from a Lincoln? Can anyone shed light on this at all?
Posted: Fri 21. Feb 2014, 12:12
by Partsetal
EDG-6316-B is the Engineering No. for B9SZ-6312-A which was used before 2-1-60, and C0ME-6316-B is the Engineering No. for C0SZ-6312-A used from 2-1-60.
Posted: Fri 21. Feb 2014, 21:58
by halloran
Thank you so much for this information that helps out a whole bunch! I do know my block is a 1959 engine so that's probably why there are some discrepancies between the crank pulleys. I sent both pulleys back to Lincoln Land to get the issue remedied and this information will help me inform Al as to what and why there is a difference in the damper. Thanks so much again!
Posted: Wed 28. Jan 2015, 07:54
by VidyBidneth
I might have to rebuild several 1960 430 V8s for Continental Mark Vs. Has anyone used rebuilt engines from this company that's often on ebay?
http://barnetthighperformance.com/engin ... 2-lincoln/
If they provide engine rebuilds with pistons that provide decent compression better than 7 or 7.5 to 1, then these might be worth considering.
Posted: Wed 28. Jan 2015, 18:58
by Shelby#18
I don't know about that company. But the photos they show are the flat top pistons.
Check out the thread here;
viewtopic.php?f=2&t=67
Lots of great info.
