Hi again...
I wonder about the vacuum pipe attached to the crank case...
To WHAT shall it be connected and should it be any junction on it for any more connections???
I will post a picture of the actual engine and pipe during the day.
Vacuum pipe???
- t_of_sweden
- Music instruments you're playing: Bass
Vacuum pipe???
T.
Edsel Citation 4-d HT 1958
- t_of_sweden
Re: Vacuum pipe???
goes to the vacuum wiper motor. do you still have the vacuum pump on the bottom of the oil pump
Re: Vacuum pipe???
Like he said. I think it was also supplying the car's unique central ball joint lubricating system. Not sure if this is s.th. that I read in the driver's Manual. These pics are made a long time ago, so I might miss on details. The first photo shows the nippel where the rubber vac. hose gets attached.
For the full story you might want to read this: viewtopic.php?f=42&t=393
- t_of_sweden
Re: Vacuum pipe???
Hi..
It's been a long time with diffirent problems för me but at least my MEL 430 is running exept for ONE problem...
It seems like it will burn oil on the right side (1-4) but not on the left side (6-8)...
I haven't got the vacuumpump in the crankcase and I did'nt have it there when I stripped the engine down.
Is there ANY possability that this pipe that is connected to the same hose as the vacuum tank, and trough the joint hose that is connected to the intake manifold CAN be using that as a straw and provide the right side with extra oil wich shouldn't be coming that way to the valves and in to the combustion room???
T.
Re: Vacuum pipe???
Simply block the nipple if you're not using a vac. pump. The nipple would normally inhale air w. the vac. pump connected. If no vac. pump is installed air (oil steam) is escaping out of the crankcase. Not ideal if you have the nipple connected w. a hose to the vac. canister or other devices. This oil steam could als be drawn all the way up to your brake booster if it shares the same vac. path. Just block it and take a few spins and watch your tail pipe.
Off coarse your problem can be related to s.th. different. Just my 2 cts on your vac. pump question
- t_of_sweden
Re: Vacuum pipe???
I blocked the nipple and got rid of the smoke at once, but can this do any harm to the engine to block it, I was thinking if the crank case ventilation will work as it should???
If that might be the case, are there any other solutions?
T.
Re: Vacuum pipe???
Glad it solved the problem. The nipple and the vac. pump thing has nothing to do w. the crank case ventilation. Blocking the nipple won't do any harm to your engine. Since there is no vac. pump attached it's simply a hole in the wall.
I can't remember exactly how the cc ventilation works on a MEL as it is very long time ago since I rebuilt one of these. I think it has some hole in the back side of the block where the fumes escape into the area between the block and the steel plate that separates the block from the transmission bell housing.
Many people convert this system into a pos. cc ventilation via the valve covers into the air filter base plate or in the case of the MEL via the oil filler cap into either the carb port or right into the air filter base plate.
So, blocking this nipple won't do any bad thing if there's no vac. pump involved.
