bore and stoke of mel lincoln
ltman
Post by ltman » Sat 3. Jan 2009, 07:14
What is the Bore and stroke of all the mel motors
Re: bore and stoke of mel lincoln
Post by Theo » Sat 3. Jan 2009, 08:29
383 cid engine...........4,30" X 3,30"
410 cid engine...........4,20" X 3,70"
430 cid engine...........4,30" X 3,70"
462 cid engine...........4,38" X 3,83"
Beep
Post by Beep » Tue 6. Jan 2009, 07:48
Can a 410 (4.2 bore) be bored to a 430 size (4.3) safely? I have found a NOS set of forged 11.5:1 4.3 standard sized pistons.
MEL ENGINE SPECS 1958/1968
Post by KULTULZ » Wed 7. Jan 2009, 15:47
MEL (MERCURY-EDSEL-LINCOLN) Engine Specifications 1958/1968
383C.I. Bore 4.30” x Stroke 3.30” (1958/59) (MERC)
410C.I. Bore 4.20” x Stroke 3.70” (1958) (EDSEL)
430C.I. Bore 4.30” x Stroke 3.70” (1958/65) (LINC-MERC-TBIRD)
462C.I. Bore 4.38” x Stroke 3.83” (1966/68) (LINC)
1958 MERCURY
383C.I. 4V (Monterey Low-Torque)
312HP @ 4600 RPM CR 10.5 To 1
383C.I. 4V (Montclair Hi-Torque)
330HP @ 4600 RPM CR 10.5 To 1
430C.I. 4V
360HP @ 4600 RPM CR 10.5 To 1
430C.I 6V
400 HP (Super Marauder)
1958 EDSEL
410C.I. 4V (E-475)
345HP @ 4600 RPM CR 10.5 To 1
475 ft.lb. Torque
1958 LINCOLN
430C.I. 4V
375HP @ 4800 RPM CR 10.5 To 1
430C.I. 6V
400HP @4600 RPM
1959 MERCURY
383C.I. 2V
280HP @ 4400 RPM CR 10.0 To 1
383C.I. 4V
322HP @ 4600 RPM CR 10.0 To 1
430C.I. 4V
345HP @ 4400 RPM CR 10.0 To 1
1959 LINCOLN
430C.I. 4V
350HP @ 4400 RPM CR 10.0 To 1
1959 THUNDERBIRD
430C.I. 4V
1960 MERCURY
430C.I. 2V
310hp @ 4100 RPM CR 10.0 To 1
1960 LINCOLN
430C.I. 2V
315HP @ 4100 RPM CR 10.0 To 1
1960 THUNDERBIRD
430C.I. 4V
350HP @ 4400 RPM CR 10.2 To 1
1961 LINCOLN
430C.I. 2V
300HP @ 4100 RPM CR 10.0 To 1
1962 LINCOLN
430C.I. 2V
300HP
1963 LINCOLN
430C.I. 4V
320HP @ 4600 RPM CR 10.0 To 1
1964 LINCOLN
430C.I. 4V
320HP
1965 LINCOLN
430C.I. 4V
320HP
1966 LINCOLN
462C.I. 4V
340HP @ 4600 RPM CR 10.25 To 1
1967 LINCOLN
462C.I. 4V
340HP
1968 LINCOLN
462C.I. 4V
340HP
There may be mistakes in some of the ratings. They vary by publication. But this will give an idea of how the engine(s) progressed/digressed.
Source- Standard Catalog of FORD 1903-1998 Edited by Ron Kowalke
____________________________________________
Post by KULTULZ » Wed 7. Jan 2009, 15:54
I don't know the answer to this question. You would think so as MEL would not have to cast more than one block. There were a few 410 users on the old board. Maybe if you cruise through there you can find an E-Mail for one of them. Having it sonic checked is the only other way I would know.
Ted
Post by Ted » Wed 7. Jan 2009, 17:34
Beep wrote:Can a 410 (4.2 bore) be bored to a 430 size (4.3) safely? I have found a NOS set of forged 11.5:1 4.3 standard sized pistons.
Here's a sonic test sheet for a '58 Edsel 410 that was already 0.060" over. It potentially could have been bored out to 4.300" and still had the prerequisite 0.100" minimum remaining. This particular block had a porosity problem in one of the cylinders and was replaced with another block rather than sleeve the questionable cylinder as this engine had a history of other issues also. If core shift is taken into account on a block that's still a standard bore or close, then the cylinders can be offset bored to keep a more uniform cylinder wall thickness.
MEL Sonic Test 385X499.JPG (33.37 KiB) Viewed 30726 times
Ted Eaton. www.eatonbalancing.com
Post by KULTULZ » Thu 8. Jan 2009, 02:23
Now that's what I call an informative post... :shock:
THANX TED!
ltman
Post by ltman » Wed 18. Feb 2009, 17:22
Ted i gess you have bult some bad mels to I no your info will be greatly apreshated over hear
thedsel
Post by thedsel » Thu 16. Apr 2009, 14:06
Yes, My Citation 410 is now a 430.
Dave
austlinc
Post by austlinc » Tue 21. Apr 2009, 07:30
Hello guys,
Does anyone know what the conrod lenght and piston pin diameter is for the 430 and the 462?
Also were the 462 created by opening up the bore from 4.30" to 4.38" and using the bigger crank in a 430 block?
Are the 430 and 462 identical besides the piston and crank?
Cheers Angelo
