DIY 033 Having a problem with starting the car when hot.
Posted: Mon 6. Jul 2020, 16:43
by 59lincolnrag
Revision A (10/06/2023) Revised information. some part rewritten for clarity.
Revision B (5/27/2025) Added last paragraph Group 31 Batteries.
Are you Having a problem with starting the car when hot?
Starts up no problems in the morning or a cold start. After driving it awhile and parking it, come back to the car 15 or 30 minutes later to start it, Cranks once then stops turning, kind of like it has a dead battery. Leave the car alone for another 20 minutes or more and it starts up again.
Yes this is very typical of these older cars I'm speaking specifically a 430 CID Lincoln, Mercury or Ford..... it certainly happens with other engines as well.
1-Be sure your timing is set correctly.
2-If Needed, Replace your Battery. I have fitted a larger battery with more cranking Amps.
3-Replace Starter and battery cables. Use a large gage where possible. Do not use those quick repair bolt on terminals. This is the number one cause of slow cranking.
4-Replace the ground strap to the fire wall. You may want to Install an additional ground strap from the engine to the firewall or to the frame.
5- You can add a heat shield to the starter as well as slipping the starter cable through a piece of hose as added heat protection for the cable.
6-Adjust you idle at least 700 RPM I have mine at 800 RPM
7-Check your main thermostat. Is it at the specified temperature? You may need to pull the water pump and remove the two smaller thermostats in the block. They go bad quite often.
8- You can also replace the fan with a flex fan for additional cooling.
9- One more thing I noticed. In the distributor the vacuum advance will stick in the advanced position. Be sure the advance is working correctly.
This is problematic with the old style rotating plate with ball bearings. It will rust up and stick in the advanced position.
You will need to Remove the distributor and thoroughly clean it. Be sure the plate rotates smoothly.
The newer distributors actually pivot and that pivot point can break or get dislodged. Again a good cleaning and possible replacement of the plate will remedy that problem
These are the things that I typically do as routine maintenance. with these cars
Please review DIY008 Distributor Vac Advance Renew / Timing Adj M-E-L 430
I have two 59 Lincolns with the 430. Same issue. Here is what I did. The standard battery is 650 cranking AMPS. I replaced both batteries with a Group 31 HD truck battery. I also fabricated new battery trays and hold-downs. Next I made custom Battery cables 00 Gauge (2/0 AWG) Copper Battery Cables with an additional Cable from the engine block to the firewall. Rubber motor mounts insulate the engine from a proper ground. I added a heat shield on the battery tray and made a heat shield for the starter. I made a new cable going from the solenoid to the starter adding an insulated sleeve used for spark plugs. Not done yet. In the distributor make sure the advance moves freely. I noticed on one car the distributor was rusted in place. (See Above!) The early 59 had a plate riding on ball bearings whereas the later build 59 had a pivoting vacuum advance plate. Also make sure the Vacuum diaphragm in in working order. What a difference It cranks much faster. starts right up!
