DIY012 MEL Starters...NEW UPDATED.....4/20/2020 Rev B Add additional details
DIY012 MEL Starters...UPDATED.....7/20/2020 Rev C Add starter removal procedure
1959 Lincoln 430 V8 starter replacement (58, 59 and 60 Lincoln)
Disconnect the battery.
In order to remove the starter you will need to remove the motor mount nuts and carefully raise the engine.
Caution: when raising the engine make sure it does not hit the vacuum wiper motor
you may need to remove it.
Remove the passenger side motor mount.
Remove the Generator
Block up the engine with wood blocks.
You may need to loosen the exhaust system from the manifolds.
Remove the starter cable'
Remove the three bolts
The starter should come out by moving it forward.
You may need to tilt the engine slightly to clear the frame.
I purchased my stater from Blax Auto Parts in Ridgefield NJ.
This starter is very common and is used on many applications.
Centrifugal Starter I used was part number 3115.
The correct Part number is 3117. However, The book does not list this unit, it has been discontinued.
The new starter will need to be clocked or it will not line up.
This means you will need to change out the end plate with the correct keyway. Thats the only way the new stater will work. Check the condition of the bronze bushing. You my need to press the new bushing into the old starter end plate.
OR.....You can special order Part # 3117 ....this is a build to order unit using your starter for the 430 engine.
Now is a good time to replace the starter cable. You may want to solder the lugs on each end to insure a good connection. I also shielded the cable with a piece of hose wrapped in foil tape over the cable or another suitable material. This will help those hard to start hot engines.
By: USA Industries....Toll free help line .......1-800-875-6582
Real nice unit.
The end plate orients or clocks the starter correctly so the the stud clears the exhaust manifold flange.[/b]
Notice on the center starter and the end plate on the right, the two inboard through holes are about one inch apart or about 10 degrees from the key-way .....(part # 3115) Thats where the two long bolts hold the starter together.
Here is the actual key-way ... I marked on the starter just where the key-way should be. The starter to the left shows the correct location.....
In this illustration the starter part # 3115 "out of the box" IT WILL NOT WORK. The positive cable stud interferes with the exhaust manifold.
Here is the starter installed with the correct end plate. (starter part #3117)
Here is some very good information...
Buyer's Guide for Unit Number: 3115
Make Model Years Engine Options
Ford Full Size 61-56 All
Ford Thunderbird 61-56 All
Ford Truck
F Series 64-62 All Centrifugal Starter
Ford Truck 61-56 All
Ford Truck F500 - F900
Medium Duty (Gas Eng) 64-62 V8-4.9
Ford Truck 61-56 All Std
Lincoln All Models 60-58 All Centrifugal Starter
Lincoln 57-56 All
Mercury Full Size 61-56 All
Cross Reference companies for Unit Number: 3115
Company Name Cross Reference Number Company Type
AMPERE 3115 Competitor Company
ARROW 34-1144 Competitor Company
ARROW 34-1054 Competitor Company
ARROW 34-1055 Competitor Company
ARROW 34-1058 Competitor Company
ARROWHEAD 3115 Competitor Company
BBB 3115 Competitor Company
BECK ARNLEY 187-6163 Competitor Company
BECK ARNLEY 187-6164 Competitor Company
CPC 3123 Competitor Company
CPC 3115 Competitor Company
DELCOREMAN 323-210 Competitor Company
DELCOREMAN 336-1001 Competitor Company
DIXIE S2003 Competitor Company
EXCEL 3115 Competitor Company
FORD FAY11001A OEM Company
FORD SA519 OEM Company
FORD SA526 OEM Company
FORD B9S11002A OEM Company
FORD SA622 OEM Company
FORD FAR11001A OEM Company
FORD FAR11002A OEM Company
FORD 2900550 OEM Company
GARNER 3115 Competitor Company
LESTER 3123 Competitor Company
LESTER 3115 Competitor Company
LESTER 3125 Competitor Company
LESTER 3117 Competitor Company
METRO 02-1515 Competitor Company
MIDSTATE 21-3115 Competitor Company
MPA 3123 Competitor Company
NASTRA 3123 Competitor Company
NASTRA 3115 Competitor Company
PRECISION 3126 Competitor Company
PRECISION 3125 Competitor Company
PRO PLUS 3115 Competitor Company
PRO PLUS 3123 Competitor Company
QUALITY 3115 Competitor Company
RAYLOC 44-4230 Competitor Company
RAYLOC 44-9608 Competitor Company
RAYLOC 44-9609 Competitor Company
RAYLOC 44-9627 Competitor Company
RELIANCE 3115 Competitor Company
TALON 76163 Competitor Company
TALON 76164 Competitor Company
WESTLING 72-3123 Competitor Company
WESTLING 72-3115 Competitor Company
WORLDWIDE 25113 Competitor Company
WORLDWIDE 25214 Competitor Company
WORLDWIDE 60210 Competitor Company
Alternate/OEM Part Number(s): 3115, B6A11002A, C3NF11002E, FAR11001A, FAR11002A
DIY 012 MEL Starters...NEW UPDATED.....
- 59lincolnrag
- 59lincolnrag
Re: DIY012 MEL Starters...NEW UPDATED.....4/20/2020
- 59lincolnrag
