Super Marauder tripower carb alternatives
Hello, just picked up an original ford supermarauder tripower intake for my 58 Park Lane. It has the proper outer carbs but center is missing. Is there a good alternative carb to use if I can't find an original. I also will need linkage. Is aftermarket available or does it need to be custom made. The tripower fuel pumps and lines look tough to get as well, is there another route for that also. I HAVE 2 2300 HOLLEYS ONE FROM A 58 Edsel the other from a 59 Tbird either for parts or rebuild if they are a good choice. any advise or direction is welcome. thanks Dozer430
Re: Super Marauder tripower carb alternatives
I found a site on line that lists all the vintage carbs. I was able to find every carb made for 58 mecury's inlcuding tripowers. they also list the rebuild kit which gives me the opinion that if they use the same kit in the same year they should work ok on my intake. the site is carbkitsource.com. I hope it can be of some use to other readers.
Joe Bunetic can make you a carb and linkage. I have some options if you are looking for an original.
