I'll be gently squeezing my parts
December 23 2008 at 10:40 AM
FElony  (Login FelonyFord)
with a 40-ton press I picked up. I need a source for those chingies you use to change bearings and other stuff. I don't know the names. Pieces of round and u-shaped and thick flat steel that I've seen at machine shops. I didn't see anything at Harbor Freight. Do I have to hijack a Snap-On tool truck?
(Login cammerfe)
I'm under the....
December 23 2008, 11:19 AM
impression that the stuff you're talking about is all home-made.
KS
FElony
(Login FelonyFord)
Nope
December 23 2008, 11:24 AM
I don't think so. The shop I dealt with back in Cal had an array of these items in incremental sizes perched on wall pegs, including the chingies to press pistons pins on and off.
(Login gaffney1951)
I got some through ...
December 23 2008, 11:32 AM
Harbor Frieght but it was 8-10 years ago. Did you try thier online catolog. I believe the proper term is doohickey. Mike
FElony
(Login FelonyFord)
Harbor Freight
December 23 2008, 3:05 PM
Well, doohickey didn't work too well, either. However, I found this:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=6834
Not as much as I was looking for, but at least I know the correct general term now. I guess shop guys in this forum are using sledge hammers to R&R their non-FE piston pins and axle bearings.
(Login Scode67FB)
Re: Harbor Freight
December 23 2008, 5:54 PM
FElony
(Login FelonyFord)
No
December 23 2008, 7:04 PM
I already have bearing splitters. I'm looking for press plates.
(Login redstangbob)
chingie
December 23 2008, 12:42 PM
is a chingie the same as a ching-a-letta? Thats what my side kicks used to call things in Amarillo 30 some years ago.
FElony
(Login FelonyFord)
Re: chingie
December 23 2008, 2:21 PM
Chingie is short for chingadero, Spanish slang for "fu#*ing thing", more or less. I have heard many Hispanics in L.A. use chingadero, but I believe "chingie" to be utilized mostly by us Anglos. I'm sure your Texas version probably has much the same meaning.
Related: one of the most hilarious country-style recordings ever... I bought this when it first came out.
http://www.artistdirect.com/nad/store/artist/album/0,,63751,00.html
(Login MT63AFX)
Try contacting Dake, info below.......I didn't see anything on their site......
December 23 2008, 6:41 PM
........Dake - Division of JSJ Corporation
724 Robbins Road · Grand Haven, MI 49417
Phone: 800.937.3253
Fax 800.846.3253
FGCofA member #4908
MCGC member #75
(Login FE4RD)
short pieces of pipe...
December 25 2008, 9:37 AM
...you probably know that short pieces of schedule 40 pipe fits many bearing races perfectly.
I would go around to local plumber shops and see if you can pick through their scrap pile for short cuts. Also, try local industrial hydraulic dealers. Schedule 80 & 120 pipe is sometimes used, and the x-tra & xx-tra thick walls are great for many uses.
FElony
(Login FelonyFord)
Thanks for the extra tips
December 25 2008, 3:07 PM
I do not know a schedule 40 from a train schedule, but I'll learn.
Current Topic - I'll be gently squeezing my parts
