oil pump driveshaft
December 2 2008 at 6:55 AM
Jason Engle  (Login jakengle)
I am running a new, stock oil pump in my hopped up 390--without getting into the stock vs. HV vs. HP oil pump debate, is there any reason to run an ARP oil pump drive shaft if I am using a stock oil pump?
http://www.supermotors.net/vehicles/registry/9026
(Login FishCakes428)
For the price........cheap insurance....JMO n/m
December 2 2008, 6:57 AM
(Login gzbo427)
Yes, call doug the PumpBuilder & buy his
December 2 2008, 7:32 AM
for the insurance
(Login TA28)
never broke stock but broke fordmotorsport twice
December 2 2008, 7:37 AM
agree with above cheap insurance. stock never broke but have twisted them.
arp / pumpbuilders all good
broke 2 ford motorsport shafts right at oil pump base.
This message has been edited by TA28 on Dec 2, 2008 7:38 AM
(Login qikbbstang)
When you think about it the FoMoCo FordMotorsport FE drives were dimensionally
December 2 2008, 7:58 AM
the same as Ford OEM this meant the metal was the same only the tempering was different..........That means you get into a mess with flexible vs rigid and that opens a whole new can of worms
(Login qikbbstang)
Ford Power Parts offered HDTruck oil pumps that required larger dia oil pump driveshafts
December 2 2008, 8:06 AM
in turn they offered a HD large Dia shaft that fit the lager input on the HD Truck pumps drive rotor and was necked down to stock FE size to mate with the distributor. Since the drive comes off the Distrib gear the whole thing was likely BS since the weakest part of the drive drove the oil pump anyway...
gene
(Login gene12320)
oil pump shaft
December 2 2008, 4:22 PM
Doug sells that pump and shaft now
Ray Hillebrand
(Login Rhillebrand)
Re: Ford Power Parts offered HDTruck oil pumps that required larger dia oil pump driveshafts
December 2 2008, 8:17 PM
I bought one of Dougs HD truck pumps and the bigger shaft and they are good quality pieces. I agree the necked down area at the distributor is probably the weakest but the bigger diameter shaft will stop twisting in the whole shaft and that is a plus.
Call Doug and get his advice.
moose
(Login moose47)
oil shaft
December 2 2008, 2:57 PM
I bought a Fordmotorsports shaft once. It broke. I called them and was told that my oil pump locked up. It didn't. Had to go through the engine one more time. Needless to say, I won't be buying another. Moose.
fairlanes
My Three Fairlanes
-moose
This message has been edited by moose47 on Dec 2, 2008 4:02 PM
This message has been edited by moose47 on Dec 2, 2008 4:01 PM
Current Topic - oil pump driveshaft
