Oil supplimentNovember 3 2008 at 11:14 AM |  Joel (Login tall69) Members |
| I finally got my car on the road, two years after I bought it. I changed my oil, which had been in there since my break in and dyno session last fall. It was Rotella and a bottle of crane super breakin lube. Is it a good idea to run a supplement in the oil for a while, or always? It's a solid lifter cam with a 130lbs on the seat and maybe 340lbs open. If yes, what's a good zinc supplement to add?
Joel
1970 Torino Cobra 429SCJ/4sp 4.30 Locker
472ci - 480HP\518LB-FT installed
| Author | Reply |
Gene (Login gene12320) Members | comp cams additive | November 3 2008, 11:41 AM |
I use the Comp Cams zinc additive in every change. It is a good idea, especially with a solid cam. |
| Current Topic - Oil suppliment |
