"Year of the Cammer" Stub Cams from Bill Coon
October 20 2008 at 10:48 AM
  (Login twistedcrankcammer)
Bill Coon is producing new stub cams for the cammer.
The new Stub Cams are made from 8620 steel with propper heat treat.
The new Stub Cams will feature a new improved key and keyway, yet still work with factory Ford gears as well as Bills new gears.
The new Stub Cams will feature more precise machining of the shaft.
The new Stub Cams, when paired with Bills new gears will have a modification to improve oiling to both chains.
I have listed an identical post with price and order contact information in the classifieds.
Roger
(Login johnvermeersch501)
Rodger, what is
October 20 2008, 12:37 PM
different from the stubs that Bill has gotten from me previosly,?? Ive had them available for the last 8 / 10 years, with both hex and threaded holes...
(Login mtrain)
Stupid question but, ............
October 20 2008, 3:06 PM
why cant an old cam be used with the last journals cut off? Sorry, Ive only seen these motors internals from pictures, but it looks {from the pictures} like a regular cam that is cut into two parts after the first two journals, what am I missing? Does it have a key instead of a dowel pin?..........Mike U
Mike, the
October 20 2008, 3:21 PM
hub is larger dia. for the top gear, and has a keyway...could be done with dedicated cam gear.....
RWJ
(Login tdm434m)
Stub cam
October 20 2008, 5:33 PM
The SOHC stub cam has a stub sticking out the front about 1/2" dia and about 1-2" long that goes thru the timing cover. This is necessary to support the shaft when the chains are on it, RWJ
(Login daveshoe)
Technical details are requested.
October 20 2008, 6:48 PM
It has been brought to my attention that this post sounds a bit much like an advertisement. The reason is it contains several comments (proper heat treat, more precise, improved oiling) without technical detail.
I am sure you've received technical detail from Bill on why improved heat treat, etc, is beneficial. Can you add technical content which overrides the sales value of this post.
Note that if a post reads the same in the tech forum as in the classifieds, it may not contain enough technical content.
Thanks,
Shoe.
Current Topic - "Year of the Cammer" Stub Cams from Bill Coon
