galaxy rear
October 11 2008 at 7:55 AM
  (Login fastphil)
does a 67 galaxy come with 28 or 31 spline axles?
(Login hawkrod)
Yes
October 11 2008, 8:05 AM
A 67 Galaxie comes with 28 or 31 spline rear axles. It can be either. Hawkrod
Hawkrod
39 Ford Deluxe Coupe
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
(Login fastphil)
thanks
October 11 2008, 8:12 AM
guess i'll start pulling it out.
(Login gaffney1951)
67 Gal ...
October 11 2008, 10:27 AM
The 31 spline version is the WAR 9 3/8" version. These axles are not interchangeable with a 9" 31 spline differential. The splines are the same but the axle lengths are different. The axle housings are the same. Mike
(Login hawkrod)
The WAR case is not a 9 3/8 and wasn't used in 67 N/M
October 11 2008, 3:07 PM
Hawkrod
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
(Login gaffney1951)
May be ...
October 11 2008, 7:12 PM
wrong on The WAR designation but the axle length info is correct. Was going by memory, Would have to hike up the hill and check the old case to make sure. Mike
(Login qikbbstang)
A always thought WAR's production was ceased by early 60s..right? n/m
October 11 2008, 8:07 PM
x
(Login hawkrod)
Yes, The WAR case was a late 50's very early 60's 9 inch N/M
October 11 2008, 9:49 PM
Hawkrod
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
(Login daveshoe)
9" didn't show up until 1960 or so.
October 12 2008, 10:26 AM
The first of the 9" differentials were available from 1957-1959 or so. These were actually 8-3/4" diffs. Something was modified in 1960 and all the production ratios seem to have changed. The result was the 9" gearset. Not sure why ford did this, but the 9" is referred to in factory literature as the 8-3/4 or 9", particularly when buying gears.
A few years later, the 9-3/8" differential was released, and it contained a gearset with either a 9-3/8" ring gear or else a gearset with a 9-3/4" ring gear. You will sometimes hear the 9-3/8" diff called the 9-3/4", particularly when buying gears. The cases seem to be the same between the 9-3/8" and 9-3/4", but I may be wrong.
JMO,
Shoe.
(Login hawkrod)
8 3/4 and 9 inch are the same thing except for outer ring gear diameter
October 12 2008, 5:53 PM
The 9 was made in 57 for heavy duty applications and part numbers were the 4.11 was a B7A 4209-F, the 3.89 was a B7A 4209-J, the 3.70 was a B7A 4209-M and in 58 they added B8AZ-4209-C wich was a 3.25. For 57 there were also 8 3/4 inch in most regular applications and the 3.70 was a B7A 4209-A, the 3.89 was a B7A 4209-E and the 4.11 was B7A 4209-C. Most rears are 8 3/4 but the 9" was there from the get go. Hawkrod
Hawkrod
59 Tbird 430
60 Lincoln Premier
(2)62 Tbirds
86 SVO mustang
76 F250 Crew Cab
1969 Mach I
Current Topic - galaxy rear
