blower ignition
October 10 2008 at 7:33 AM
  (Login fastphil)
every time i here of a blown fe,it envolves an intake spacer for the blower drive clear the distributor.why aren't the intakes made to clear it anyway? what would you use for ignition,back in "the day" if you didn't use a distributor.now we can use digital msd and crank trigger.was/is there a cam drive set-up available? i would like to build my car period correct.don't want the msd or the spacer. am i stuck using the spacer or is there an intake available?
(Login MT63AFX)
Try to find the expensive/rare timing cover with angled distributor mount....or use......
October 10 2008, 7:44 AM
......a short/low magneto, I think, LOL, Rod.
FGCofA member #4908
MCGC member #75
(Login BattlestarGalactic)
I use the spacer......
October 10 2008, 9:07 AM
but a stock ignition. Ya, that's right, single points and all-no MSD.
I've got a factory 427 marine Mallory dual point tach drive I've been wanting to put in for the real hot rod look. Got the cable and tach too. The bad part is this model dizzy is about as tall even with crab cap that I still can't get cap off with blower on manifold.
The tach dizzy I have in my race car is the short body model but it's not a crap cap(takes different body and can't mix caps-they are different diameters). It could be done, but have to do some creative machine work.
1969 F100 428/4spd
1967 F100 352/now a 4 spd!
1959 B Model Mack
Inthegarge
(Login inthegarge)
Back in the day I had an offset dist drive that relocated
October 10 2008, 9:26 AM
the dist out and to the side of the intake. Have not seen one lately but marine apps have a variety solutions. RW
(Login fastphil)
where
October 10 2008, 6:58 PM
do you know where to locate the offset dist?
Greg
(Login GregoryM)
Another question.
October 10 2008, 11:02 AM
Will the M/T front covers w/the distributor drive fit under a stock water pump? I doubt it but I don't know for sure. If you can't run the stock water pump, why not use a flathead type distributor run off the cam? Mallory makes a nice looking electronic unit that seems ideal. Just asking.
JMO
(Login JMO_)
front (belt) drive, DIS, offset or M/T cover...
October 10 2008, 4:59 PM
(Login fastphil)
that's it
October 10 2008, 6:57 PM
that's what i was looking for.that dist.probably will not work with a stock water pump.don't think the boat style pump will move enough water in a closed system.not on the street anyway.are these cam drives still available?
JMO
(Login JMO_)
if you can find a CAST cover (needs some thickness) you can get Summers Bros to add drive
October 11 2008, 7:45 AM
You would want a cast aluminum cover, maybe a Blue Thunder cover, or a Dove cover, or an old marine cover. Talk to Summers and they'll machine it to accept one of their drives (which are sold separately from the SBC and BBC covers they show on their website). Or, find a drive on your own and machine a cover if you have the contacts or resources.
Summers Bros isn't the only company that makes separate drive units for cam-drive applications...
Summers Bros/
This message has been edited by JMO_ on Oct 11, 2008 7:50 AM
Current Topic - blower ignition
