Distributor question?
October 9 2008 at 1:19 PM
  (Login fair69)
I'm getting close to have my 428 cj complete. Was looking at the DUI distributor has coil inside of the cap like the chevys. Has anyone used this dist.? Pros and Cons?
Tommy-T
(Select Login Tommy-T)
I have one...
October 9 2008, 2:10 PM
...in the 460 for my Bonneville project. Worked perfect on the dyno...haven't made it to the salt yet.
BEWARE: it makes your motor look like a Chevy!
Kerry
(Login sportyworty)
They work well but...
October 9 2008, 5:31 PM
Look like utter dog pile as previously stated. Definately rear mount application only. My sideoiler ran great but why hide the pretty motor? lots of great alternatives available.
This message has been edited by sportyworty on Oct 9, 2008 5:33 PM
(Login JA428FE)
I have one on my 351w
October 9 2008, 7:25 PM
Check the curve. I wasn't happy with what they set me up with. Also they sit very high. You might not be able to run the air filter that you want to. Hood clearance might be an issue. So bad they offer an offset adapter from the carb to the filter housing. Still pretty darn tall. I had to raise my air filter up 4" to clear the dist. John
1970 Land Cruiser, 351w, NP435
(locked up front and rear)
1965 Galaxie, 428, C6, 3.89 gear,
Detroit locker
1979 Spectra Day Cruiser
stock 350ci Brand X, Mercruiser..53mph on GPS
This message has been edited by JA428FE on Oct 9, 2008 7:32 PM
This message has been edited by JA428FE on Oct 9, 2008 7:31 PM
(Login gaffney1951)
I used one on my 460 also ....
October 9 2008, 7:44 PM
Had the same issue with the curve and they do take up alot of room, otherwise they use good components(Dyna module). Using reworked Duraspark and a 6 AL box on the 2 latest projects. Mike
Ray Hillebrand
(Login Rhillebrand)
I've got one on the shelf in the garage.
October 9 2008, 8:02 PM
I just could not bring myself to put it on the 427. I am running a Mallory Unilite instead. I'm sure they would work fine for you but I just can't see it looking right lol
(Login fair69)
Re: I've got one on the shelf in the garage.
October 10 2008, 6:32 AM
Would you be interested in selling the distributor? Also, could I get a picture of it? Thanks Randy
(Login Rhillebrand)
I will post a pic this weekend.
October 10 2008, 1:19 PM
nm
(Login Mario428)
WHY WHY WHY
October 10 2008, 2:54 AM
Would you put the ugliest POS dizzy in the world front and center in your motor all the while announcing "I really like chevies"???????????
I truly do not understand how in the hell they ever sold one of those POS's never mind the number they did sell.
And don't give me the "cheap price" crap, its an FE, make it look like it should.
Rod C
(Login MT63AFX)
I agree Mario, I have the same feeling towards MSD dizzy w/windowed GM caps, LOL......n/m
October 10 2008, 5:17 AM
FGCofA member #4908
MCGC member #75
Dave Walters
(Login blueoval67)
I gotta agree...
October 10 2008, 6:22 AM
they look really out of place on a Ford. That big honking distributor has got to be in the way of something due to its size. Instead of using an old technology like that, step up to an MSD. It will be more money but worth it. You don't need to go full race MSD stuff just the basics will do nicely. A nice billet dist. with a blaster coil and a 6 box will work great. If the budget doesn't allow that at least use the later model Duraspark set up. You can get everything you need from Autozone relatively cheap and it will work well.
Dave Walters
427 Galaxie Registry
Website
http://home.ptd.net/~pwalters
(Login fair69)
Re: I gotta agree...
October 10 2008, 6:35 AM
Well just running out of funds for the 428. This is the first ford fe I have ever done and its just very expensive for everything. But I think I will be very happy with my results though. Thanks for all the replies.
(Login RichFerguson)
Running out of funds?
October 10 2008, 8:27 AM
Well! I would suggest a stock Motorcraft electronic distributor with stock external control module. Or a stock points type distributor with Pertronix set up. You can upgrade when funds allow.
(Login Rhillebrand)
October 10 2008, 1:25 PM
Randy, I can relate to the lack of funds problem. I have a distributor with a Per Lux unit in it that works fine. In fact, I removed it from my old 390 that was in the Galaxie. I planned to put it in the 451 but acquired a Mallory Unilite that I am now running. I have a spare Mallory dual point I keep in the trunk in case the Unilite goes tits up. You can have the Per Lux distributor for the cost of shipping. Always glad to help out when I can. BTW, Per Lux was the company name before Pertronix, its the same unit as a Pertronix.
(Login 1966Tbird)
i've got one on my 302 here's some pics
October 10 2008, 11:05 AM
note how big it is!!! i had to use an offset aircleaner and still you can't use some of the high performance coils this is when i just put it in now i have a mallory coil that i took a sawzall and a file to to make it fit
Photobucket
Photobucket
Photobucket
Current Topic - Distributor question?
