427 / 428 Blocks are not made of nodular iron
November 30 2008 at 7:06 AM
Royce  (Login RoyceP)
Response to high nichel content blocks
In fact the 428 CJ blocks are made from the same superior iron alloy that Ford used for its 240 CI 6 cylinder and its 302 - 2V that year.
There was no special block alloy for anything except the 427 block.
There was no special iron for crankshaft castings for any engine size. Ford used a crankshaft grade nodular iron formula which is NOT the same formula as the nodular iron formula that Ford used for axle cases or engine block main caps.
