The choke and run scenario showed that it probably has a vacuum or carburetion issue.
If you have another carb, I'd swap it, even temporarily, but you could easily have a vacuum leak and cause the same issues.
Did this carb/intake combo run before the cam swap?
- 71 F100 shortbed 4x4, 397 cid FE, headers, Street Dominator, 280H, 5 lug Dana 60, 4 speed
