| It is wrongNovember 17 2008 at 4:34 AM | pmw (Login PmW-SOHC) Members |
Response to Traction-Lok diagram is in error |
| I ran into the same thing , I have a '70 Ford driveline manual that shows the shim in the correct position and I have a '72 driveline manual that shows the same diagram but with the shim in the wrong position such as the diagram that was posted . that shim does go on the outside od the clutch hub , NOT between the hub and gear . |
