| I agree,November 12 2008 at 12:30 PM |  Pippin (Login TorinoBP88) Members |
Response to Absolutily, put in an FE BUT, if that an all original car |
Id FE it, it looks cool and drives great with all the torque. While i do like the 289 in my mustang, and have had a fairlane with the 289, the 390's are a kick in the pants! I am putting a 67 GT engine in my car (with a 428 cranks) stock C7 heads and all.
Keep everything you remove!
Consider keeping the stock FE heads. W/ CJ valves, it will run really well, my head rebuild with stainless valves (PEP) and bronze guides and milling, cost about $750, not too bad. I did some port clean up myself. You only are behind about 35 lbs over EDL heads.
If the engine is in good shape, is should be an in-expensive re-build, even if its $100 to $125 for a sleeve. What happened to it anyway. You sure it needs a sleeve?
1967 FE 390GT engine: 416 CID 233/238* @ 0.050 Solid Lifter w/ 4 spd TL.
1968 GT/CS Mustang. 289/c4
1995 Mercedes e320 I6 DOHC, 216 HP wagon.
2003 Tundra SR5, 4.7 DOHC, 4x4.
Another Galaxie (one day.)
Oh and a Bicycle - daily driver to save gas for the 'F'un 'E'xcursions. |
