air cup
November 8 2008 at 2:44 PM
  (Login tomposthuma)
Response to ...he was the inventor of the air-cup valve-actuation system...no rockers needed.
He had the air cup system before it was later used in F1. You still needed rockers it just used air instead of spring tension to close the valves. I have no idea if his system was his idea or whether it was ever used on a running engine.
It certainly wasn't a bad idea at all and air powered valvespring compressors (for removal) are in common use nowadays.
