How they test carbs
November 5 2008 at 5:03 PM
Jay Brown  (Select Login jaybnve)
Response to Still confused about the need to convert 2V cfm ratings to 4V calculations....
The carburetor is bolted to a large vacuum chamber. The vacuum in the chamber is controlled, and airflow is measured through the carb with the butterflies wide open.
For testing two barrel carbs, the vacuum in the chamber is set of 3". For testing four barrel carbs, the vacuum is set to 1.5".
If you took the same carb, and tested it at both 1.5" of vacuum and 3" of vacuum, it would flow more air at 3" of vacuum. More vacuum equals more airflow; this should be fairly intuitive. So, this is why you need to convert the numbers, so that you normalize the airflow between the two different test methods.
There is no such difference in any kind of testing on the dyno. CFM depends on the pressure drop across the carb, and will be greater at 3" of vacuum than it is at 1.5" of vacuum. So, CFM is not CFM, because it is dependent on other variables. As a measurement, however, torque is torque; it can't vary with conditions the way CFM can. However, please note that the torque output of the engine CAN vary with conditions, such as temperature and humidity. That is why a dyno has a built in weather station, to calculate a correction factor so that test results taken in different weather conditions can be fairly compared.
Jay Brown
www.network54.com/Realm/JaysPictures/jaktsm.JPG www.network54.com/Realm/JaysPictures/smplaq.JPG" alt="[linked image]">
