| Mustang engine mountsOctober 24 2008 at 6:37 PM | Steve Heer (Login steveheer) Members |
Response to Help with motor mounts |
| The 67 Mustang frame mounts are the same as the big block mounts for 68 through 70. It's the smallblock insulators that are the oddball to find for 67. If your frame mounts are not to cobbled up and are still original 67 V8 mounts all you need are the block plates, they use 3 bolts on each side of the 4 available on the block, and the insulators which are the same left and right. It's pretty easy stuff to find.
Steve
67 Mustang fb FE 431ci |
