The only thing
October 22 2008 at 9:10 PM
Mike  (Login mwbbstang)
Response to Something can't be "stock" on that front end...
not stock are the front drag shocks. When I assembled this car from a bare shell, I reused the original coil springs (after powder coating). I don't recall measuring the free height or testing the rate, but I do remember looking to see if they had been cut (no). Is it possible I have smallblock springs? I suppose anything is possible on an old car. The rear suspension is preloaded with the traction bars lowering it a bit. I wound up removing the rear drag shocks and went with progressive coilovers to hook up better. The rake is mostly from the bigs and littles.
