| oil pressureOctober 12 2008 at 6:04 PM | Jake R (Login c6ae-c) Members |
Response to Yes, dial bore measured... |
| These are classic symptoms of oil clearance issues.
You did not mention the oil clearances for the cam. If that clearance is a bit loose (like the rest of them) and the camshaft oil holes are not located at the bottom of the bores it would contribute to an oil pressure issue as described.
