| Don't Use zMaxDecember 30 2002 at 7:16 AM No score for this post | PCD (no login) from IP address 12.21.127.68 |
Response to Yep, Just Amazing |
I put zMax in my 1990 Thunderbird Super Coupe. I am now rebuilding my engine because zMax turned the hoses on the fuel rails to goo, turned the timing cover seal to goo causing an oil leak, and weakened my head gasket causing a head gasket failure. If the Head Gaskets hadn't went, I'd have had an engine fire from the fuel hoses leaking.
I had no problems with gaskets and fuel line hoses before I used the zMax. I usually post on www.tccoa.com, a Thunderbird and Cougar website. |
