Back to the  MASTER INDEX Files
Back to the  Chris Craft Commander Forum
 SMALL BLOCK CHEVROLET MARINE ENGINE INFORMATION
(Updated February 22, 2008)
NEW >>> Chris Craft Power ( Just about every V8 motor CC ever built )
http://www.network54.com/Forum/424840/message/1172181250/
NEW >>> RACOR fuel/water separator and filter
http://www.network54.com/Forum/424840/message/1185213909
NEW >>> Ballast resistor and 350Q running problems
http://www.network54.com/Forum/424840/message/1185804396
NEW >>> Carb problem troubleshooting issues
http://www.network54.com/Forum/424840/message/1186411196
NEW >>> Starting problems ( Generic to all motors )
http://www.network54.com/Forum/424840/message/1187100002
NEW >>> Splitfire plug wires ( Recommended by Tim Toth )
http://www.network54.com/Forum/424840/message/1188489076
NEW >>> Edelbrock carb swap
http://www.network54.com/Forum/424840/message/1190492092
NEW >>> Edelbrock marine carb
http://www.network54.com/Forum/424840/message/1202489422
NEW >>> Tilt shims for carbs
http://www.network54.com/Forum/424840/message/1190387283
NEW >>> Fuel lines and hoses
http://www.network54.com/Forum/424840/message/1190815261
NEW >>> 327F Pertronix Ignition Installation
http://www.network54.com/Forum/424840/message/1191080453
NEW >>> Trusted Commander Parts Suppliers
http://www.network54.com/Forum/424840/message/1191628881
NEW >>> 350Q distributor issues
http://www.network54.com/Forum/424840/message/1183358543
NEW >>> Rotation ( an explanation of Standard and Reverse )
http://www.network54.com/Forum/424840/message/1157641525
NEW >>> Winterization plumbing circuit
http://www.network54.com/Forum/424840/message/1194883544
NEW >>> Small Block Q series timing ( Conflicting data )
http://www.network54.com/Forum/424840/message/1197417897
NEW >>> Engine hoist
http://www.network54.com/Forum/424840/message/1197132572
350Q Rebuilding Thread (A great “how to” thread with lots of photos, from Mark Weller)
http://www.network54.com/Forum/424840/message/1159145359/350 (Camshaft discussion)
http://www.network54.com/Forum/424840/message/1160009596 (Discovery of bad camshaft)
http://www.network54.com/Forum/424840/message/1160704886 (Back from the machine shop)
http://www.network54.com/Forum/424840/message/1163817431 (Reassembly)
Pressure Regulators Can Cause Engine Overheating
http://www.network54.com/Forum/424840/message/1164411296
327F Resurrection after 6 years (Video smoking down the neighborhood and specs)
http://www.network54.com/Forum/424840/message/1164395538
307QLV and 350Q Interchangeable Parts (Interesting reference thread)
http://www.network54.com/Forum/424840/message/1164153141
327Q Details and Specifications
http://www.network54.com/Forum/424840/message/1163045639
Sherwood 327F and 427 Sea Water Pump (Photo Documentation)
(This is a 427 thread, but both engines can use the same pump)
http://www.network54.com/Forum/424840/message/1156595176
Sherwood Dual Impeller Sea Water Pump (Old style 4-ports)
http://www.network54.com/Forum/424840/message/1156386823/
350Q fuel problems (a diagnostic thread)
http://www.network54.com/Forum/424840/message/1154465436
350Q Rebuild Issues (a diagnostic and technical thread)
http://www.network54.com/Forum/424840/message/1149706439
327 and 350 F motor documentation (Insight into the model deviations)
http://www.network54.com/Forum/424840/thread/1152650335
Fuel delivery, anti-siphon issues (diagnostic thread)
http://www.network54.com/Forum/424840/thread/1151550143
327F Cooling Diagram
http://www.network54.com/Forum/424840/message/1140195682
Early 283 and 327 Photo Documentation (Lots of Photos)
http://www.network54.com/Forum/message?forumid=424840&messageid=1126289673
Marine engine troubleshooting guide (Scans)
http://www.network54.com/Forum/message?forumid=424840&messageid=1123099503
350Q engine diagnostics, Mark Weller’s diagnostic thread.
http://www.network54.com/Forum/424840/message/1143830136
350Q Timing
http://www.network54.com/Forum/424840/message/1147532943
Small Block Chevy Cylinder Head Rebuilding Project
http://www.network54.com/Forum/424840/message/1139761806
283 and 327 Specifications and Operations statement (scans)
http://www.network54.com/Forum/424840/message/1123103583/
Small Block Chevrolet Heat Exchanger Modification to Volvo Penta (Photo)
http://www.network54.com/Forum/message?forumid=424840&messageid=1121461323
Carter AFB Carb Specs (Photos)
http://www.network54.com/Forum/message?forumid=424840&messageid=1125684478
http://www.network54.com/Forum/424840/message/1139721799
More info on Carter Carbs (work sheet scan)
http://www.network54.com/Forum/424840/message/1144702953
Generic Hard Starting issues
http://www.network54.com/Forum/424840/message/1138021506
Cold Start Tips
http://www.network54.com/Forum/424840/message/1138320614
Spark Plug Reference Material (Photos)
http://www.network54.com/Forum/message?forumid=424840&messageid=1124816710
Sherwood Pump Photos and Specs (Photos)
http://www.network54.com/Forum/424840/message/1134077503
Pertronix Ignition System (Primarily for the 427 but good info for the SBC too) Photos
http://www.network54.com/Forum/424840/message/1131313926
MANY THANKS  to everyone who has contributed to the information in these files.  This forum will always be a work in progress.  It’s a way to file away all of my Commander information for personal use, and it’s also a way to share it with anyone else who may be interested, or who may need the info (for their personal and non-commercial purposes), or may want to post, ask questions, etc.   Because much of the information on the forum is not checked for accuracy,  represents opinions in some cases from unknown sources, and may represent a safety or personal/financial liability if acted upon, the information in this forum and Master Index is offered with the very best of intentions, but it MUST be validated by the user before utilization in any way.   If anyone sees a link in this index that does not work, of finds any inaccuracies, please post a note and I’ll try to fix it!
Regards, all the best,
 ©2005, ©2006, ©2007, ©2008, Chris-Craft Commander Forum, Inc.,  ©2005, ©2006, ©2007, ©2008, chriscraftcommander.com.   Information on this site may be copied for individual personal use, but any other reproduction or use requires written approval.
