Network54
         Home
 Search
 My Account
 Help
 Help   >>  Support Index   >>  Network54 Admin Forum
Problem with table tags on new HTML parser
November 17 2008 at 6:57 PM
  (Login esquiloesperto)
from IP address 189.48.28.179
Tele Norte Leste Participações S.A.
Contagem,
Brazil
We've in troubles with formatting table tags after the new HTML parser implementation.
The new parser just rejects and discards all these tags.
All (span) style tags (font-family, color, size, etc.), positioning tags (cellpadding, cellspacing, align, border, etc.).
I must say that whole borders simply disappeared. None of them ever appears.
Many (or all) Network54 forums are experiencing this. These are the forums I've tested the malfunction:
http://www.network54.com/Forum/248242
http://www.network54.com/Forum/599702
http://www.network54.com/Forum/544784
http://www.network54.com/Forum/493632
http://www.network54.com/Forum/562807
Look at my signature below, it was a formatted table but now I must use images to achieve the same result. Its code was:
This code currently results in:
- WHAT A DIFFERENCE!!!
Posted under licence from Dirson (Premier login jomajero).
Look at these other code samples:
  Teste 1
Teste 2
Teste 3
Ought result:
But now under new parser we see this:
  Teste 1
Teste 2
Teste 3
[linked image] [linked image] [linked image]
201.18.109.56
Ibirité, 15
Brazil
Re: Problem with table tags on new HTML parser
November 19 2008, 11:21 AM
I used a trick to get my signature like before... 'Cause the attribute "border" didn't run.
Thanks for bring the ALIGN tag to run again. But its "middle" attribute doesn't work yet.
Please restore attributes BORDER, BORDERCOLOR, CELLPADDING, CELLSPACING.
Also give to SPAN and STYLE (with whole their attribs) the chance to work out again.
189.48.28.132
Contagem, 15
Brazil
December 10 2008, 9:36 AM
HTML table tags are back! - Thank you a lot! Great job!
It is good to see it working again:
Returned different shapes, but works equal. Very good!
Teste 1
Teste 2
Teste 3
And the CSS stylesheets too, see below. Wow!!! --- lol --
### --- Thank You a Lot !!! --- ####
I am very, very happy 'cause you've heard my claims!
- These issues are solved, at least, to me.
Thank you Cris Moser. N54 staff has done a great job.
You did your better!
Current Topic - Problem with table tags on new HTML parser
 Copyright © 1999-2005 Network54. All rights reserved.   Terms of Use   Privacy Statement
