| Original Message |
Tim (no login) Posted Apr 21, 2008 7:27 PM
Paul,before you put your carbs on the engine,check the throttle butterfly`s for a "perfect wide open"position.Turn the carb upside down and then rotate the linkage to WOT and check the throttle vavles.They all should be at a 90 degree intersect with the carb base .
I have yet to see a perfect wide open setting on an OEM Chris Craft carb.
Tim |
