| spins freelyOctober 16 2008 at 8:50 AM | Mark Weller (no login) |
Response to Re: Fire and fuel, and won't start? |
| whoa "Also i can spin the shaft freely but when i crank the starter it begins to spin and seems to spin at the same speed as the crank." do you mean you can spin the distributor shaft a full 360 degrees freely or it moves freely and springs back to its original position? Or are you talking about a different shaft? If you can spin the distributor shaft freel in a full circle you have another issue altogether as something has broken inside the distributor. What kind of distributor do you have Mallory or an after market one?
