| Total timingSeptember 7 2008 at 5:51 AM | Bill (Login billinstuart) |
Response to Seem to be getting nowhere |
| Total timing is the problem.
Use the flywheel as a timing indicator. Find TDC ACCURATELY, then lay out 30 degrees on the flywheel.
3.14Xdiameter=circumference.
Circumference/12=Distance along outer edge of flywheel at 30degrees. Mark 30 degrees, run up engine until no more advance shows.
You're wasting time doing this without a timing light. doesn't have to be fancy advance unit. |
