| Further diagnosticsJuly 22 2008 at 8:29 AM | Bill (Login billinstuart) |
Response to This doesn't sound good |
| Bottom end noises get worse as the engine warms up. If the intensity doesn't change with temperature, I'd look further. rod bearings have little effect on oil pressure as they oil as the holes line up in the main bearings. Perhaps an oil analysis will confirm/eliminate bearing failure without dropping the pan. Remove the oil filter and cut it open to see if there's metal in it.
how did you check the coupler? |
