| 35 PropsJune 24 2008 at 8:37 AM | Mark Weller (no login) |
Response to Proper Props for a 35 Commander? |
| Well I have 350's with 235 hp and I have 20 x 22 3 blade props with 2.5 to 1 reduction, but I also weigh around 18,000 lbs. I don't think you are that heavy as I have the Dbl Cabin. 21 x 21 doesn't sound too far off but if you are hitting 4000 rpms and still have throttle to go you need some more pitch. Max throttle I am at 4200 rpm and the best I have seen is right around 30 mph but I don't leave it there long enough to know if I am actually hitting top end mine takes a while to wind up to max speed even though the rpms will go right to the max. I guess I can get around 32 or 34 totally maxed out but I see no reason to do it. |
