| detonation?May 27 2008 at 4:38 PM | Bill (Login billinstuart) |
Response to Works for me |
| Early Chevy heads need a close "quench" area to create turbulence in the chamber. The distance from the piston top to the flat area of the head should be 0.040 or a little less. This turbulence helps prevent detonation, and requires less ignition lead. Make sure there are no sharp edges in the combustion chamber. With a slightly fat mixture and not too aggressive timing (30 degrees @ 3000 rpms) you should be ok with 89 octane. You can't hear detonation. |
